totall2tall
My oil pressure sensor switch broke I super glued the plastic back on and everything looks fine. My question is can you run your bike with a broken one and not hurt it until I get a new one? Just don't know if the glue got the spring stuck and will it hurt the motor in any way if it does not talk to the ecu? Will it fly apart and leak oil under pressure? The metal and part screwed into the motor is fine just the plastic broke by the nut and broke the stud off that touches the spring. Thanks in advance.
