flcmcya
Had a dual coil setup installed on my K9.... Very nice job.
Now I ride a ways and it beeps then cuts out.....
First time It happened the reg plug was potentially not tight..... bike wouldn't even light up....then charged the bat to 12.8 and got to the flash / beep....then the next day everything lit up like nothing happened.
Cleaned my terminals and tightened a couple slightly loose coil connections.... went for a spin today and I made it two miles before it quit.
Then I pulled over and tried the key ...... everything lit up..... and I cruised home......
Mech said EHC right away but I cant buy that as I didn't have a prob prior to the mod.
Appears to be the same one!
A new key switch was added and it isn't real tight in the hole....is this a ground point?
Anybody have this phenomena and successfully troubleshoot it as I also though maybe a bad coil ....but then I would still run on one cylinder? Yah.
Thanks
Randall
Thanks
Randall
