IronHorse570
Happy Sunday gentleman, long time no talk to. So now the weather is getting nice again in Central Pa. So I'm having some issues with my Dog. Starts and runs fine, but twice now from the past 4 times I rode it, it died. Like someone hit the kill switch or turned the key off. The first time I got about 3 miles from home on local roads, the horn sounded, flashers came on and it died. Turned key off and back on, horn sounded no speedo, no lights, no starter nothing. Today came of exit ramp from I-180 onto I-80 again about 3 miles from house, felt like it was out of gas, however that was not the issue, flashers came on and it died on the shoulder. I turned the key off, then back on, finally got it to start. Road to meet friends at gas station, checked battery terminals, ground, EHC Connectors A&B both tight. Decided to bale on ride go home and check further. Cleaned A&B connectors and repacked with Dielectric grease, checked for frayed wires, etc found nothing. Checked a bunch of old threads on EHC issues, etc. Some maybe leading me to believe the EHC is going bad. I have an 18 light EHC, but if I understand correctly, they don't just work intermittently, if it dies it dies period. So one question I can't answer is when is each lights supposed to illuminate? if I am looking at it correctly, when running the Controller, Power, and Ignition lights would be lit correct? If I understand correct, with that said, if I press the horn button the horn light would come on etc. The reason I ask is no matter whether high beams, horns, directionals, etc, nothing lights up on the EHC, except for the 3 power, controller and ignition. Any help would be greatly appreciated. Thanks
