Hey Guys,
I'm having a hard time trying to figure out what I have done here.
I had a loose clutch hub nut and I re tightened down to 120/130ftlbs. Reassembled and readjusted the clutch twice and I the clutch lever feels good and I saw the clutch pack move out when the primary cover was off however once in gear rear tire will not spin AT ALL when Clutch Lever is pulled - Just like it's in gear no difference with the lever pulled vs not pulled in.
I'm trying to rack my brain to figure out what I did here. Considering the lever is tight and I saw the clutch pack move in and out with the cover off I can't imagine that the ball and ramp slipped out? As a note I didn't remove the clutch plates I had taken the 4 bolts off the clutch pack then realized I could just remove the snap ring without removing the clutch. So I put the 4 bolts back in tightened down to 20ft/lbs per spec. So I really couldn't have put it together wrong?
Bent clutch pushrod when putting in the throwout bearing?
