KaptinAmerika
No I'm not saying the EHC is bad. I'm just saying that the test box alone really doesn't tell you much. It gives you a down and dirty pass or fail on the EHC but it won't tell you if something else in the system is causing the issue.
Air Ride mode is in parallel with the Headlight mode. Air Ride Mode is activated by pushing the start button prior to pushing the run button when you first turn the key on or after you have started the motor. Doesn't matter if you don't have air ride as it is still part of the EHC's functions.
Have you tested your Right Hand Control board for continuity and shorts as well as for shorts in the right hand control harness back to the EHC?
