MossBerg590
Thank you, I will try that and see what happens.
Hope that was your problem. Thanks for the updateJust an update. I took the tank off and checked all connection. I seen 2 wires that had the insulation rubbed off a tiny bit in a spot but enough that wire was showing. I wrapped both wires with electrical tape and put tank back on and took it for a ride. I use my headlights, brakes,blinkers, horn and bike didn't short and die once. Im not sure if that was the problem or if my bike just isnt doing it right now because its intermittent. I will give it a week and see if it happens and let everyone know. Also, I followed the wire that got rubbbed and it is the wire for the right controls. We will see, staying hopeful!!![]()
1. This about one connector short of sending the Hbox out to be bench burned.WELL... Rode the bike... hit rear brake... bike died.
Those brake switches still connected? Let me borrow that brick wall for a second :bang:On the way home, it didn't die once...This is driving me crazy!
Here are 3 variables:Could it still be the brakes even if they aren't always being used when the bike dies?
No it doesnt, unless blinkers, brakes etc are used( only when bike acts up)What happens when riding at speed and you pull the clutch lever in. Does the bike die?
