Compression Release failure
BroadBand
Since late 60's
SS link for electric compression release
Parts
Replacement Parts
l 90-4915 Release kit, compression
l 90-4914 Release assembly, compression, electric
l 50-7094 Washer, compression, 14mm
l 55-1009 Cap, solenoid, silicone
l 55-1010 Harness, wiring, compression, release
l 55-1502 Connector, Deutsch, male - DTM06-2S-E004
l 55-1503 Wedge, connector locking – Deutsch #WM-2S
l 55-1504 Socket, Deutsch
l 55-1508 Connector, Deutsch female – DTN04-2P-E004CH
l 55-1509 Wedge, connector, locking- Deutsch #WM-2P
l 50-0045 Kit, compression release, socket
l 50-0046 Socket, compression release, bottom
l 50-0047 Socket, compression release, top
<LINK> for installation instructions
:flag:
copterguy
............ah, thanks very much. Just what I needed. I had already downloaded the instructions, but "Googled" the ELECTRIC COMPRESSION RELEASE 90-4914 part and voila! I love this forum..
francoblay1
The Spaniard
Would these TP CRs fit our Dogs? $28 Only.
[ame=http://www.amazon.com/TP-ENGINEERING-MANUAL-RELEASES-45-4020-21/dp/B000GTZAF0/ref=sr_1_sc_3?s=automotive&ie=UTF8&qid=1337052753&sr=1-3-spell]Amazon.com: TP ENGINEERING MANUAL COMP. RELEASES 45-4020-21: Automotive[/ame]
Cheers,
V
francoblay1
The Spaniard
Would these fit the TP rocker boxes on the 06 K9???
TP Engineering 45-4020-21 Manual Compression Release Valve
with Billet Cap
Manufactured from 303 stainless steel
Available with billet aluminum cap or threaded to accept any standard tire valve cap for a truly custom appearance
Require a .650" (1.65cm) 10mm x 1.0mm-threaded hole for installation
Made in the U.S.A.
TP Engineering ZZ 0950-0002 TP Engineering 45-4020-21 Manual Compression Release Valve with Cap For Harley-Davidson from BKRider.com
R
Ridgeback Boy
Guest
with Billet Cap
Made in the U.S.A.
Did these / will these work? I know....old thread.
Coolbreezin
No. The above C/R's are 10mm. We have 14mm holes for our C/R's. Im researching this also as Im looking to replace the electric C/R's with manuals. But I dont like the cable operated manuals from S&S.
francoblay1
The Spaniard
Bump.
Has anyone found Manual CRs for our S&S heads?
If/when mine fail I would like to go with Manual ones... (No Cable, just finger push!)
Coolbreezin
I found these a while ago and have been sitting on them wondering if they would fit our heads. I wonder if S&S has a special thread cut so we are restricted to just their products. I know S&S wouldnt tell me anything, so I havent asked. I heard we have 14mm bolt holes so I wonder if these might work. Anyone with more info would be greatly appreciated here.
Compression Release for Rev Tech Motors Harley | eBay
John won't the 14mm long reach work in the center of our heads in place of the existing electric release? I know the head would have to be machiend for the 10mm.
Never thought about the temp on the ole finger prints though
FWIW, I would NOT mess with any compression release other than the S&S ones for the S&S heads. The threads in the heads are proud, and are very fragile. :eek: You can press the threads out by just over-tightening the releases. :angry:
If you think the TP rocker boxes vs. S&S is a problem, you ain't seen nothing till you try mix and match compression releases on S&S heads. :bang:
John
I wouldn't risk it
Diesel Dan
Bump.
x2 Brother Franco!!!!!!!!! BUT if the threads in the S&S Heads are as sensitive as John says,we might be stuck with the S&S Compression Release's.......I want manual ones also......
francoblay1
The Spaniard
I bet there are some for the S&S..... I will make some inquiries! :up:
