Battery wiring
srisk
04 BDM chopper - installed a new battery. So when putting new battery I found a extra wire near negative terminal from "computer" but did not have a battery terminal connection just a wire end. Didn't install it & bike starts & runs fine. Have on trickle charger & all is well. So my question is should this wire be hooked to negative terminal??
Jwooky
You should swap the positive side cables so that the heaviest gage wire is against the battery. You want the least amount of resistance possible and the most surface contact.
francoblay1
The Spaniard
X2, and sand paper the terminals.... Nice & Clean! :2thumbs:
