Background: My dog has been sitting about 3 months because I have slowly taken off the primary and replacedthe tranny and oring seals. The tranny was leaking into the primary.
Yesterday I finally got it all back together and she fired up perfectly. Ran for abou 10 minutes then shut off. I immediately tried to restart her and she would not turn over. I looked in the gas tank and it is hard to see in there, so I went and got 3 gallons of gas and added it to the gas tank. Still nothing. I took off the breather sprayed carb cleaner in and that would cause her to turn over by only for seconds. It was getting late so I let it sit till this evening.
When I got home tonight, I went to try and start it up, she started right up. Ran for less than 10 minutes. This time I went to drive her around the block and she quit before I could make the square block around my house. Good news is from replacing the tranny seal and putting back on the primary she seems to shift and run fine (only got to second gear though).
What would cause her to start perfectly when cold but then minute she gets a little warm she shuts off?
