New filter or usedI just ran it around the block without the filter and it ran great and you put filter on and it bogs out
Filter is probably restricting flow enough to starve engine at higher rpm. Couldn't run one on my mastiff either29.5/78 it has a bad bog at 3500 rpms. It also has l.a.f drag pipes on. I got it at a shop on the Dyno now but they don't work on to many motors like these I don't think
Fastest way to LOSE major power. :bang:Has anyone heard if these are worth a crap?
My bad. I thought you were referring to a fuel filter and a velocity stack, not a velocity stack with a filter.Filter is probably restricting flow enough to starve engine at higher rpm. Couldn't run one on my mastiff either
