Do they make those for an 05+?Curtis is right there might be another problem. Is the starter aligned/shimmed? But if it is and you use this jackshaft and it breaks then you have a big problem...
Ultima Belt Drive Fix Starter Jackshaft Ultima BDL Harley The Grind Stops | eBay
Starter RebuildSend it to WSW~~~!!!!!!:2thumbs:
04 LSD, 05 RSD, Baker Proprietary set up,,His starter doesn't need rebuilding, it works. The starter is misaligned so the jack shaft is at the wrong angle. The stock jack shafts are junk. When I put my belt drive on the jack shaft was so beat up it was ready to go. (with only 4k on it)
I bought the Ulmita jack shaft and it has a cut gear that meshes better and is more HD. When I installed it I check for clearance and had to shim the starter to get it right.
I have LHD so I don't know if the same jack shaft will fit your 2005 but you can email John or Rick and they will know.
X2 on this jackshaft, I put it on mine and it works great.Curtis is right there might be another problem. Is the starter aligned/shimmed? But if it is and you use this jackshaft and it breaks then you have a big problem...
