Leak
Steele1
So I had new wheel bearings put in my back wheel and when I put everything back together I now have a leak behind my primary.. Has anyone ever had this problem? It's just weird, I thought at first maybe my belt was too tight and caused something but everyone I've talked to says that wouldn't happen.. I have a open primary too btw so I know it's transmission fluid.. If anyone can help that would be great, thanks very much!
Removing your tire may not have had anything to do with it, then maybe it had. When a seal is ready to go, it will just leak.
Maybe when the back tire/belt was aligned, it was adjusted tighter than before causing more tension on the tranny shaft bearing thats already worn, and the seal is now leaking. Just a shot in the dark, but as stated above, Andrew's da man
