... all steel plates have rounded edges on one side and sharp of the other. in all cases, install the plates with the sharp edge toward the Transmission.
He says tomato, I say two may toe. Guys drag race and install the plates facing into the engine or the flat facing you. Either way, the stack is that all the flats run together.
Old Harley steel plates have a riveted ball cage that touches the clutch outer and this has less friction as would a tab around that end of the plate and would have more. Also, they stamp "OUT" on the cut side, so the assembly is cut facing you.
And also, when you remove Japanese friction plates, all the cuts face the pressure plate. The old Honda CBX had the pressure plate facing in. When those were disassembled from the factory, the cuts were facing the pressure plate.
With your hands, pray you assemble it correctly. While there, press your fingers together. If you lay you one hand over the top of your other hand, press your fingers now. See how the plates move together as in memory not warring with a reversed plate as if praying [they face] the right direction?
Now, technically, technically you are going to get your ass handed to you for not installing the basics staring at you in the face is Harley saying this is how you face the flats and the Japs explaining the same move.
You say toe may toe, and I'm going to throw tomatoes at the stage you better understand both factories moves is step on your toes, stay out of my pit you do not assemble that part as per. No offense, just a technicality vs. the engineers of both camps.
Study the part, study the factories moves vs. the net move you read on line.
Details my man. You don't find thishit in a book, but observe years of assembly/disassembly of parts is parts.
"It only goes together one way" is my mode of transpour some theory at it.
1. Plate [flat] facing you = Say I push on a wall with my fingers spread right at the edges. Do I have full contact? Yes.
2. Plate facing the round side = Say my fingers now are curled around the wall. Do I have full pressure? No.
Make sense we follow the pressure plate?
Signed,
NOLTT (no one listens to turtle)
Pee. Yes.
That's just the plate assembly. Now, we get to the push rod adjustment, we'za gonna squeeze'a another theory at you, you are going to lose at the line [traffic light] is your only crime. :up:
