Not Charging
FST954
I have a 04 Ridgeback, The battery voltage will not go past 12.6v I have 30 volts at stator when I rev the bike the voltage does go up to 40 to 50 volts
I just replaced the voltage regulator and still only 12.6v at the battery
There is a relay/breaker under the seat at the input side I only have 12,6 volts
The regulator I just put in is a cycle electric the compufire that I took out had a ground wire attached to the back of it the cycle electric does not, I am not sure if that would be the problem
Any help is appreciated
Wire look cut anywhere on that other v/reg? That's a possibility if the other wire does not have a black or green wire [usually] for ground.
I'd let the bike idle and now check against these numbers. Breakout means, if at idle you have a 22amp stator and 16 is the low, 19 is book, you may have a 32amp stator and be within spec. Get it? But if you are at 16 on a 19 call, I'd call your stator out of spec, not a new v/reg that is controlling the DC to the battery.
If the relay has 12.6v to each peg, there is no break in the flow, correct? The v/reg if not grounded we question that missing wire, battery is grounded, stator is grounded, v/reg is hot and those wires sort of count as a grounding loop so as to overcharge the battery, but you are seeing no output and the v/reg shows it?
You changed the old v/reg because? "I'm throwing parts at it." So are we saying the old v/reg might be fine if you did not spec the wires of the first v/reg?
http://www.dnlauto.com/pdf/Harley Davidson full wave charging systems.pdf
FST954
At the input side of the breaker that comes from the VR it is only 12.6V that is why I assumed that was the issue. At the stator it sits at 30V at Idle when I rev up to 4000 rpm it goes up to 60V, that is why I thought it was the VR
chacha
Chaff Your EHC!!
Utube a ground continuity test for the stator. Had a similar problem recently and that was the test that failed it.
DRBarnhart
Insert title here...
Do you have continuity through the circuit breaker? Are you sure the voltage regulator has a really good, clean ground?
Dennis
FST954
The ground is what concerns me, on the stock VR it has a pig tail ground coming off the backside of it, on the cycle electric one it does not have a pig tail ground on it
francoblay1
The Spaniard
If I am not mistaken the ground on those are in the same bolts-to frame.... make sure they are clean (old locktite maybe) & tight.
DRBarnhart
I just checked and I have continuity from 1 of the plugs from the stator to ground on the engine bolt
If you mean you have continuity from one of the pins of the stator plug to ground... you have a problem. :down:
Dennis
Dennis
Look at this stator's 2 wires.
All this is, is one long wire wrapped around those center cores. Also, there is a coating on the wires. When they lay on each other they do not make contact. This can now send out that AC wave.
2 wires:
My ohm meter wants to swing to infinity as if I touched both meter probes together by themselves. I can now see this single wire having a few variables:
1. What if there is a break in the wire? That is one long wire and if there is a chain broken say, we say this is = Junk.
2. What if there are 3 wires out of the stator? We see it as a 3-phase or 3 separate windings that if one phase is broken as in a wire, there is no longer and equal phasing system = Junk.
3. What if a 3 or 2-phase wire group has the coating getting so hot, it melts the surrounding coating on the other wire it is laying next to and this now is shorting itself = Junk.
4. What if I connect the wire phases to each other, I should have infinity or continue [continuity] is that path from one wire end to the other = Good.
5. What if I connect the wire to ground and see if the ohm meter acts as if I never touched both prongs together, the meter is the reader = Good.
6. WATT if I add up all I did to the wires and it was a simple 2-step:
a. A phasing wire is either short to ground or it is not.
b. A phasing wire to wire shows a complete circle so says the ohm meter.
c. A is 2 directions in the AC of it.
d. A rotor with magnet may lower the AC output. But I always see a stator wire bringing back the output, more than replacing a magnet.
7. Electricity is all about 'balance' and if one wire is not equal in output = Junk.
:iagree: there is a need for a better brief on the checks done... I am :confused: too...
Here's your debrief, franco
All this is, is blah, blah, blah... = Junk.
Denny,
Your one liners are no help. Give a debrief or sit down. No offense.
It can't be said any clearer than my "one liner" Sven...
And, no worries Sven, I'm not offended if you don't understand me... :up:
Dennis
Well, I'd like to see you explain heart surgery with one line. :roll: No offense.
:hi:
FST954
I appreciate all of the input it looks like it is the stator I will be ordering one from Cycle Electric tomorrow along with the rotor, I saw a good write up in the How To section on replacing it and it does not look to painful
I will update everyone when I am done
Thanks again for all of the feedback
FST954
Just an update, the rotor was shot it had no teeth left on it, I went ahead and ordered the Compufire kit which had the stator, rotor and VR all went well and the bike is up and running I appreciate all of the help and advice. For those of you who are not mechanically inclined it was a fairly simple job. There is a good write up in the How To Section on replacing the stator and rotor
