Brew
All I'm having an issue with installing the left extended control on my 2008 Mastiff and want to see if anyone has ran into this issue. It seems that when I install the left side, my shift linkage interferes with the down tube when pushing the lever down (as in down shifting). Has anyone ran across this issue? If so what did you do to correct the issue? I performed a search and found no mention of this issue.
Here is a pic of my stock control on the shifter side. It's several inches from the down tube and has a spacer between the lver and the push rod:
Here's a pic of the 2.5" mount for the left side. If you can imagine it mounted in place where the stock one is, it would fit fine, it's just the shift lever where the push rod mounts that's the problem. The nut that secures the push rod is hitting the down tube when I install this one :
Here's a pick of the extension for the shift side. I had it on the scoot and I adjusted the push rod ends all the way in and all the way out and still had interference. If anyone has put the 2.5 entensions on an older model Mastiff, could you please post up some pics of this side so I can see what kind of clearance you have and explain what you did.
I checked my Ridgeback and it has a shorter spacer between the push rod and shift lever. If I were to put on a shorter spacer the push rod wont be straight and i really dont want that.
