06 pitbull horn location
Misfit
So tryin to get my dog inspected and found out my horn does not work.
I have searched all over the bike cant seem to locate it, also checked the owners man and wire diagram no luck there.
I have also found that my tach lights will blink all on and off when in neutral sitting at a light or just randomly.
any help is greatly appreciated.:flag:
Doggin it
I have a 2002 Pit and mine is located under the bike hanging from a bolt. I have to be careful when jacking the bike up. Right in front of the rear tire. Also your idle may be set to low. That will make your tach lights go haywire. Does it go away when you give it gas?
Cliff
Thors
05 Pit here...my horn is just in front of the battery box inside the little fairing that covers the area. It's bolted to the battery box itself.
Misfit
awesome guys ty for the info.
I will check the bat box for the horn
and
I will look into the idle issue would that also cause the excessive exhaust popping when I let off the throttle?
Dawgboy
Idle speed wouldn't cause popping on deceleration. Mine does that as well. Might play with jetting but I say it's typical.
francoblay1
The Spaniard
Would you like the Carb Manual too? :D
Oh......... I am off to bed... tomorrow I will feel sorry for myself........ NOT!!!!! :2thumbs:
C´mon guys......... EVERYTHING is here.... just L:eek::eek:K... do a search... and don´t forget to click on my Signature Block´s Link... there you will find the BEST "How To" posted by the BEST of this Forum....
Just Do It..
Wankers!!!
Off to bed... its been an "Interesting" Day...........
But .... "I am Watching You" :D
:whoop:
francoblay1
The Spaniard
BTW.......... different Subject noe... but.... it seems to me that......... those "Red & Blues" are doing their job, hu?
I´ve noticed "those wnakers" who just are "watching" and wondering... "should I join??"
That´s Kool Bros... we like INTROS its just a matter of Respect..
Believe o not... this is my first and only Forum......... I was "scared" ... had not a clue... I did find this site on Google.. becouse I was looking for help about my K9...... in another Continent.........
You Know what Bros?
This IS the BEST Fucking Forum in Earth!!!!:whoop:
:2thumbs::cheers::cheers::2thumbs::2thumbs::cheers:
I love you guys! What would I do without you........ :2thumbs:
Misfit
So I did not find the horn but I did play with the idle a bit and it seems to have helped.
The carb diagram would be awesome I have the PDF of the 2006 owners man. but it is very limited.
Redog76
Thanks again for the hookup Franco!!! I've gone over the manual though, and still can't narrow down what color wire operates the horn.
I see the location in front of the battery, but no wires. I assume I need to pull the covering off. There is a small empty connector with a black and purple wire connecting.? I guess next step is to pull the button if I cant figure it out. My wife is nervous without the horn!!!!
Thanks for any help.
Dragonslave
My bike decel pops too. Decel pop can also be caused by removing the baffles from the pipes, intake leaks, or incorrect carb tuning.
francoblay1
The Spaniard
Have you sort it out yet?
Peckerwood
Carb tuning videos available on the S&S website. Easy to fix your decel popping, you're running too lean. 10 minute job at most. Good luck.
