European light change
AsKarO
Hi all.
I have a 2009 Ridgeback (NO efi) imported from U.S.A. and i live in Italy then i need to change the rear and front light, I need to know if someone have the electric wire schematic (i have the 2007 wire diagram...it's the same???)and if someone have already make this operation...
The rear light have 3 wire but i need to install a 4 wire light (position/stop and separated orange turn light..)
Thank you.
francoblay1
The Spaniard
You can integrate All-In-One, position/stop & turn signal in the same bucket. So you will end up with no extra lights hanging of your fender. :up:
aspen874
Franco, is your man to talk to, there are several members here on the forum from Europe,
hopefully someone will be able to give you a "how to".
AsKarO
I seperated the wires from the brakes levers and put them on a switch to operate the brake lights. This will not harm your EHC.
I was given this advice from a member here who does a lot of homologations in Germany.
My EHC is still ok after 3 years of operation.
There are CE marked rear lights that you can install in the OEM housings:
LED Rücklicht/Blinker Einheit COLORADO zum Einbau, ohne Metallgehäuse, Paar, E-geprüft. - Rücklicht- / Blinkersets - Rückleuchten - Beleuchtung - Motorradzubehör großer Marken
Buona fortuna!
Jochen
Thank you for information!!!:up:
Unfortunately i have already buy 2 pair of new bullet....i have only one problem....I need to remove the front forks to change the turn lights???:eek:
francoblay1
The Spaniard
Can you post a pic? I don't think you need to remove the forks at all!
The screw that hold the turn light to the "forks" is located inside the lights bucket... :confused:
AsKarO
Oooh...that's good!!!
Sorry for misunderstand...i have make a question ..Because I have not yet done this operation..tomorrow i look inside the light and i try...
Thank you for this informations!!!:2thumbs:
francoblay1
The Spaniard
Prego. :2thumbs:
