C.A. Jones
Mr. Boo is right on the money. You're already down there. Replacement rings are less than $40. Base gaskets less than $10. C.A.Jones V-Twin | Custom Builds, Parts & Service
Anybody mention checking the end gap on the rings before jamming them in the bore.Mr. Boo is right on the money. You're already down there. Replacement rings are less than $40. Base gaskets less than $10. C.A.Jones V-Twin | Custom Builds, Parts & Service
The ring end Gaps should be fall between .017 and .025 for the Compression Rings and .010 and .040 for the oil rings . I would go with what S&S recommends which is what I have on here. If you are not sure the bore size (which should be 4.125) get rings for a 4.125 + .010 over and cut them to size. Rings are easy to cut with a ring cutting tool. If you have never done a ring job (cut rings) and don't know what you are doing, get someone that knows how and save money. Match the piston to each cylinder Front piston to front cylinder and rear with rear take the rings and the above specs and have them cut for you, AMENNope, what should the gap be? I do believe the jugs have been worked over before I bought the bike because I know the previous owner sucked a carb bolt in.
That was my question too... I know it has been done and some people reckons it is just fine...Have a question? My tp rockers are the roller type. Why could I not reuse these with my new s&s box's? They fit just fine. Has no one done this?
About time you start listening:roll:That was my question too... I know it has been done and some people reckons it is just fine...
Others say it is asking for trouble.... Andrew is doing mine soon and he is one of the guys who recommends the S&S.... so.... S&S will be for me.
Mine was pretty bad as it had never been cleaned like this before. I took a scotch brite pad to it to clean all the hard stuff off. Then I actually used 1200 grit sandpaper to finish it up. Then a lot of elbow grease with mothers aluminum polish. Trust me when I say it was a pain in the ass.You almost have it looking like chrome! Good job! What all did you use to help you get it that way?
lolVery nice, what worked best for you to get to the wall of the jug in between the the fins? I has some crap still kinda on the front side of the jug. The area that's exposed the most.Nice job looks great. I know what you mean by hard work and lots of time. I just had my motor out of the frame and cleaned it. Had over 50 hours in it getting off 14 years of crud. It was well worth the time and effort.
