So after its sat since last run, day before yesterday
Battery was at 12.6v before any activity.
Then put a finger on compression release button, Hit key, did not feel them move away from finger.
started motor, battery goes down to 12.38v while running and even with multiple extended long hi rpm revs no change in battery voltage. Did several long extended revs still no rise in voltage
Once turned off it goes back to 12.68v
Both CRs, do move freely when pushed by hand up and follow finger back to the top. Also you can push them when its running and hear each cylinder change so the valves work, just not maybe not engaging electronically. (Most testing on that to come) A side note, the front rubber condom is fine, but the rear is cracked / hole where the button is. (dont think it matters just a note)
Going to test stator according to steps with muti meter, and remove wire from starter to lesson for CRs follow wires for more info on them.
Also will ride it around some and compare before and after ride voltage.
