coyote 09
The circuit breaker is good. The relay is for the horn. I have a +cable going to the circuit breaker. From the other end of the circuit breaker a cable comes out straight to the EHC to power it up . I know for a fact I have power going through it (EHC) because I have power at the ignition plus I physically tested the connection inside the plug. The last thing I'm going to check is if there is any power coming out from the ignition when I turn the key. Other than that, I think the EHC is bad. There are no other fuses or circuit breakers (visible). I really screwed the damn thing...
