Yup, I plugged mine in Florida without any issues but each his own I guess .If its just a nail causing the replacement, just put a plug in it. I got 5000 miles out of mine after I plugged it and finally had to be replaced cause it was bald.
A good plugging tool with the mushroom plugs does the same thing without removing the tire.If its not close to the sidwall, I would use a Plug/patch. Not just a plug.
They go in from the inside of the tire, pull through like a plug, but at the end of the plug is a patch to cover the whole it self too. works great.
J&P Cycles has a kit that is under 25 bucks I think. I bought one a few years back to take on the longer trips. So far, I have only had to use it on the lawn mower tire, but it is still holding up.A good plugging tool with the mushroom plugs does the same thing without removing the tire.
JP Cycles-Part Number: 200-636J&P Cycles has a kit that is under 25 bucks I think. I bought one a few years back to take on the longer trips. So far, I have only had to use it on the lawn mower tire, but it is still holding up.
thinking just cost me 15 bucksJP Cycles-Part Number: 200-636
about $40
