s&s carb switching to mikuni question!!!!
mybgdg
Hey everyone I'm switching to a mikuni hsr45 from a s&sg I have a d&m spiked intake ive already ordered the right carb support bracket from d&m to switch to the mikuni was wonderin if I need to replace the s&S intake with a mikuni intake I know they make a rubber adapter flange just was wonderin if that was gonna space the carb out to far for the fitment of the spike intake to be reinstalled I don't have a problem with buying a mikuni intake if thatswhat I need was wondering if mikuni makes a intake that doesnt require that big bulky adapter flange any pictures of some guys with mikunis and intakes would might also help thanks in advice !!!!
bigdogtech01
I don't have any pictures, but you can mount it either way. Did you get an adapter with the carb to mount to an S&S intake manifold? Otherwise, they retail for around $30.
cajun1
I have a Mikuni with D&M double cone filters and had to switch to the rubber intake adapter to install.
francoblay1
The Spaniard
Is the breather filter free-floating? or, how did you attach it to stay in position? I can't make it out on the pics.
bigdogtech01
It mounts using the head just like the original S&S backing plate. This is a nice setup and performs well for being spiked, but it's huge!! Kinda gets in the way of your leg at times. But the Mikuni carb is the way to go if you have the $$ to spend on one. This might be something to look into Franco :D
francoblay1
The Spaniard
Next Year!!!! :lol:
I was refering to the little filter attached to the hose coming from the rocker box.
john sachs
First, WHY ? :confused:
You can make your "G" carb perform every bit as well as a Mikuni. :eek:
If you're going to use a 45 MIK, you really need to get a S&S "E" manifold, as the inlet diameter of the "G" manifold is too large. :bang: The other option would be to use a Mik 45 mm intake, and then you'll need to make spacers to fit it between the heads.
"G" inlet = 52.5 mm
"E" inlet = 47.2 mm
John
