what is difference between wire plus and others
knine08
what is the difference between the wire plus retrofit system over $500 and the thunder heart upgrade module less then $200
both say re-programs the ignition curve.
pros??
cons??
08 k9 G carb
Splitlog
The Wire Plus eliminates the EHC.
The Thunderheart is a replacement for the Ignition Module.
Good to do both
knine08
looks like wire plus also does ignition and offers a new ignition switch with the kit.
am I wrong or still need thunder heart.
Well what thunderheart upgrade module? The ignition module?
I believe thunderheart makes a generic electrical system which wouldn't work with the BDM switches/controls
WP only provides a different physical ignition switch (where you put the key)based on their wiring. You still need to retain the ignition module which the stock one is made by thunderheart.
Please read my post above still looking for clarification regarding what thunderheart module you may be referring to? If it's just the ignition module that won't help you any if your computer is Fried. In the pre-03 Big Dogs I believe they used a Thunderheart Computer module to wire the bike however it will not work on 04+ without significant changes to the electrical system and components.
knine08
ok this is what I am trying to figure out, thanks for help, still learning how this bike operates.
I thought the wire plus also changed ignition box but I guess not. thats why I asked
I guess I need a break down of each system and and their function. and what goes bad. then the best solution for the replacement of each.
Splitlog
2008 service manuel
I HAVE A 2008 SERVICE MANUEL IN ("PDF ")
SEND ME YOUR EMAIL AND I WILL GET IT TO YOU
and then i will have someone else that owes me a beer :cheers: :2thumbs:
I am up to 14 members now that owe me a beer if i ever meet them.
and yes I have a LIST ,, lol
knine08
thanks for the links and help. lots of reading to do now.
I am thinking of trying the thunder heart upgrade for the tuning aspect. I would like something to fix the starting issue when batter is not 100%. and some way to prevent the draw on the battery when parked.
5 days parked and computer wont let it start, that's ridiculous.
My Vmax can sit for 6 months and still start .
Nukeranger
Nukeranger
One day I'll be out there to Southern California to meet up with you all and hang out.
Sent from my iPad using Tapatalk HD
aspen874
Knine08, I would recommend the Thunder Heart ignition, I put it on my Mastiff and really felt the bike performed better.
The batteries on all these bikes take a hard hit when starting (hence the compression releases), everyone hear will basically agree with that. Also they need to be kept on a charger when not in use.
francoblay1
The Spaniard
X2, :2thumbs:
knine08
I will start with the thunder hear for now.
reading some of the adds for wire plus they mention new ignition switch and starter wire
does this bypass the computer then?
I thought I read about one of them stopping the battery drain issue?
Jwooky
The WP modules eliminates the EHC (what you refer to as computer).
The WP modules is not a microprocessor based controller. It is basically a series of relays and switches, so no "computer".
The only reason the replace the ignition switch, is the stock is a low current switch and they use it to supply full power. A better way is to just run the stock switch through a relay, (which should have been incorporated in the module). This will retain your stock key/switch.
It will eliminate the EHC current draw issue.
I would still not recommend the WP system. It is not well developed and not reliable. It also massacres the wiring.
knine08
ok then, thunder heart programer and then try to wire in starter relay.
anyone have good schematic for this?
knine08
I am also going to get the push button switch for the starter. mounts on end of starter to manually engage starter. anyone use this?
will it work even when the EHC prevents starter from working when battery is too low.
