All valid points, thanks for the reply. I am a "don't fix it if it ain't broke" kinda guy, but will definitely take a second and third look/check with regards to the tranny. A new pushrod is a given, a new throw out assembly is a given, the bolt missing is also a given but can it have caused any damage to have it missing? I mean, 4000 miles at least is what it has done without it and who knows how many more by previous owner... I will also install a new clutch cable and keep the current one as a backup. The oil that came out of the primary was also very thick and black, something that surprised me as I changed it less than 1000 miles ago. I use the Mobil1 20-50 and have had zero clutch slipping issues. The oil in the tranny was also replaced and that oil still look good. Weird kinda scenario but whatever it takes, i will make it right.Your already there, you might as well pull the chain assembly and clutch out to check the bearings in the transmission. Not to mention yours being an '06, it's very likely you have an old main shaft in it.
Yours most likely also has the old style clutch pushrod which has a larger outside diameter than the new. So I would get a new one for sure. That and the throwout bearing assembly are both around $38 each. If you pull the clutch out, make sure you get the seal that goes into transmission case and the clutch shim that goes behind the clutch hub. Seal is $7. Shim is $3.80.
It always amazes me that someone can leave out a bolt like that after working on the bike...unreal:loony:
Thanks again for all the good advice, I am listening to each and every one of them.:2thumbs:
