Gettin' ready to take the K-9 to the Vet this week for some warranty work, and I am starting to have a clutch issue ( I think). 775 miles on an 07...After the bike gets warmed up.... 20/30 miles, when you shift from 2ed to 3ed gear the shift peg kinda sticks 1/4" or so
above where it should be.After you give it a little throttle it will ease back down in the correct position. (bike remains in gear fine, but peg will move 1/4" or so. Also, when I come to a stop...You cannot down shift thru the gears to 1st as easily as you should. After a couple of tries...you will be able to down shift to 1st.
Would like a little technical advise so I can explain it to the tech's at the dealer.
Sorry if this has been covered in a past forum.
I wish we all had technical knowledge like some do!!!!
n!!
