CLUTCH ISSUE
francoblay1
The Spaniard
Ok, the Bike is up & running again, thanks Curtis (WSW) for the quick response insending me a new starter :2thumbs:
Now... to install the starter I did unbolt and taken out the whole unit (right side) where the rod is and cable hooks up.... (Without touching anything else, not the cable neither)
I did it a couple times while waiting for the starter to arrive and I also adjusted the rod... lubricated the rod and the cable (I did not open the ramps)... put it back and all seemed fine, even more smooth than before.
Then, the starter arrive... Hurra!!! put it all back on, (piece of cake) but then SURPRISE.... the clutch lever does nothing... there is no resistence at all, the hand lever remains colapsed!!! :bang:
Any ideas before I start fucking around with it?
Note: I did start the bike for about 5 minutes without oil in the primary case, but I dont think this would have nothing to do with it as it did happen b4 I started the bike. (I couldnt help myself... had to try to see if it would start after installing a new starter, new Programable Ignition, new cam, xXx kit, etc. It did start without hesitation at the first push of the button! :whoop: )
Thanks guys.
Staffy
Check the clutch cable, its probably disengaged at the tranny end (I doubt it has snapped, you can pull it from the clutch end or from the adjusting collars to confirm that). There is a furrel that keeps it in place, that's probably come loose - you will have to once again open the cover up for that unfortunately (exhaust included)
good luck.
francoblay1
The Spaniard
good luck.
On it Staffy, :cheers:
I just wanted to avoid opening it again... but, no choice I guess! :D
There is a furrel that keeps it in place, that's probably come loose .
X2 Bummer, just wait till you get into that greasey mess:lol: or your balls came up to far on the ramp, without pressure from the clutch to return it, it will stay limp, and that is NOT good:lol:
francoblay1
The Spaniard
I tried to stay on subject but you guys went off on a tangent:roll::roll:
OK, back on track..... I´ve opened it up.... everything seems fine to me so far... now I will clean all the greasy mess and look at it properly.....
Its very hot down there.... :D
wolfen
Francoblay1, Did you ever get to the bottom of what was causing there to be no clutch pull? I`m having the same problem with my bike and it happened when I was installing the new motor ,but , I didn`t pay attention to what Joey did to fix it.
I am going to work on it right now. I will keep you posted on how it turns out.
Did you ride your Dog since the cam change? or is this your last item to fix before your first ride?:whoop:
If you haven't riden it yet, you are in for a treat.:willy_nilly:
francoblay1
The Spaniard
I have not been able to go on the road as yet..... CAN´T WAIT!!!!!! :D I just need to fix the clutch and put together some bits & pieces and off I will go. I hope to have it all done today!!! :2thumbs:
francoblay1
The Spaniard
Al right folks...
After a few hours of battling with it... I think I´ve got it.... the issue (I think) it was that I was reassembling it with the cable in the "pulled position" FIRST PIC
Then I clicked.... it does not make sense... so started all over again... SECOND PIC
Going downstairs to put it together and I will be right back... Fingers crossed
