10amp fuses continually blows
I have pdm installed on bike and worked great for some time.
The only fault is i'm blowing 10 amp (compresion fuses on every start)
what gives.
I dont have the exact diagrams but i think this should be a 5amp anyways
but there is no way it breaks it.
I don't want to damage any wires using a higher amp rating
i a) need to confrim what amp i should be using. is it 5, 10, 15, 20 or 25.
i can only think that there must be a short ? but if that's true why would i new fuse start right up. i'm at a loss.
any body have the scahmatic for pdm harness for bdm chopper 05?
Neil.
Diesel Dan
I have seen them blow fuses with a sticking or bad compression release.
Bob
:flag:
X2....Yep.....Thats where your short is at,you gotta have a Compression Release that is hung up,or a short to voltage or ground in that harness....thats why its continually blowing that fuse...
ty for your advice., Guess i'll have to trace wires. I think the release are hung up you can kinda hear it stick. Can ii just lubriate em. or do they needed replacing?
Tomtang aka Reptilejim
I had a similar problem with the compression release sticking. I cut a very small hole in each release cover and skeeted wd 40 inside each of them. Everything has been fine since and that's been since 2010. Just Sayin'
This is a GREAT NEWs. I thankyou for this knowledge. I can hear one of them sticking.
And i belive its cause it has a tear in boot , thus rain gets in and then sticks.
I'll try adding a squirt or two in the torn bubble.
Thanks so much.
Neil.
