NUKNUK
Last year, bike had one of Jake's HID lights in it, but that went out and replaced back with the stock bulb. Afterwards, anytime it was switched to Hi, it would not go back to Low beam. Just recently, harness melted and replaced with new ceramic harness, but still have the same problem. I checked all connections and even swapped out the actual switch and problem still remains. Do you guys think the harness needs replaced or is it some sort of voltage issue????
I did try the HID again with the new harness and it flickered a couple times before going into safe mode/Hi beam.
