bryant1609
I installed my Medallion Speedo yesterday and everything appeared to go smooth. I was hoping to get out on the road and test it but when I start the bike it doesn't appear to be working correctly. I installed as per the direction for a 2009 Big Dog Ridgeback.
Steps
1. Remove Tank
2. Remove Old speedo
3. Remove three wire connector
4. Plug Green wire into slot 3 of the new 4 pin connector
5. Run line from battery + side to slot 4 in 4 pin connector
6. Install Speedo
This is what happens when I turn on the Bike without starting
1. Big Dog light up for about 3 seconds and I can go thru the setting on each button.
2. Left signal flashes in Speedo but not the right
3. If I turn on the Hi beam the right signal light comes on.
If I turn the bike the Speedo goes dark but the Light signal light will still work and not the right. The Hi beam still lights the right signal turn. I get NO RPM and haven't tested the speed.
Any help please.
Steps
1. Remove Tank
6. Install Speedo
Any help please.
