hard crank no start
ASH
my 05 chopper cranks hard but does not start. i rebuilt the starter, put fresh gas in, wire brushed the plugs, installed new battery and now it cranks hard but does not fire.....any suggestions?? thanks for the help
bigdogtech01
Welcome :hi:
Better do an intro or you will get yelled at :D
Can you tell if the compression releases are working when you hit the start button? They should click and you can feel them move if you put your finger on top of the rubber boot.
bigdogtech01
I just re read this...are you stating it cranks hard, like hard to turn over? Or cranks hard, like turns over great?
ringo
if the bike has been setting for an extended period of time you may have a carb issue such as a stuck needle, preventing fuel filling the bowl.
ASH
thanks for the replies....it turns over great, i wire brushed the plugs....i will check for fire and do an intro
bigdogtech01
Ok..like others said already, might want to check for spark. A new set of plugs might help as well @ $2.50 ea :D
If the carb had fuel in it for that long, it will most likely need to be cleaned as well. The Ethanol in the fuel now a days is bad news for your fuel system. Sitting for 7 months, I'm sure it is black gunk in the float bowl.
Diesel Dan
Shitcan the sparkplugs like andy said,there cheap....Set correct gap and check for spark with a SPARK CHECKING TOOL,there cheap also......ALSO like andy said the Ethanol is horrible and VERY corrossive to fuel system components and will damage your carb quickly,especially if it has been sitting for 7 months....
If you have good,clean,strong spark,your getting fuel, and it still wont pop,or try to light off.....pull carb,its probally gummed up........AND like Sven stated from the begining,when was this thing last running,like 7 or 8 months ago??...sitting that long with carb loaded full of this new shitty fuel is no good.....
Last thing,check all your grounds and stuff under your seat,check EHC connections,make sure there good.....When I first got my bike,I had shitty connections and grounds that rattled loose all over the place...:(
Dont worry,everyone will help ya get it going,theres a lot of smart people on here:2thumbs:
Good Luck bud!
Starter spins fast with the spark plugs in it? Is that assumption? Without another word out of my mouth, one must not chase their tail and eliminate one of the amigos, so there is no doubt: 2 to go. We want to eliminate compression before attempting the other suggestions: Consider this Step #1 Penultimate step. If you have less than 100 psi or zero compression, you no longer need follow the list below. But if you have compression and they are equal between cylinders? Follow step [buy] step you follow the suggestions where needed:
Diesel Dan said:
Shitcan the sparkplugs like andy said,there cheap....Set correct gap and check for spark...
Step #2.
KaptinAmerika said:
Have you checked for spark at the plugs
Step #3. Install both plugs into their coil wires. Ground the spark plugs to the head, but away from the rushing fuel mist headed out of the cylinder or up she goes with the house. Note both sparking. If not, continue to next step.
The Diez said:
... check EHC connections,make sure there good.
Step #4
RoadRider said:
If you do [have spark] check fuel.
Step #5.
Diez said:
... and it still wont pop... pull carb,its probably gummed up
Step #6
