chopsteak
Went for a ride yesterday and noticed 3rd gear loading and unloading.thought maybe my belt had become loose because of the way it felt. 1,2,5,6 gears no slipping. This started on my last ride and I adjusted the pushrod. Loosened jam nut bottomed out rod and backed off 1/4 turn and secured nut with Allen wrench keeping rod in same position. I rebuilt the tranny 2k ago due to a main shaft bearing starting to go away. Ordered to full rebuilt kit from Baker. When I headed back home to check the primary fluid it was 50 shades of gray, and it was last changed on previous ride, maybe 30 miles on that fluid. Question is do u folks think its the clutch or internal on the trans. 3 rd gear is the worst,4 th is bad but not as bad but 1,2,5,6 gets seem to pull ok. Thanks
I pulled the clutch and was able to isolate the play in my transmission. Time for a rebuild by Andrew so I put it in the mail today. :up:
