Compu-Fire 3 Phase Charging System
francoblay1
The Spaniard
Can someone please tell me which one is the right one for my 06 K9?
1. 55560 [ame=http://www.amazon.com/Compu-Fire-Phase-Charging-System-55560/dp/B000GV9USQ/ref=sr_1_1?s=automotive&ie=UTF8&qid=1355072600&sr=1-1&keywords=Compu-Fire+40+Amp+3+Phase+Charging+System]Compu-Fire 3 Phase Charging System 55560 : Amazon.com : Automotive[/ame]
2. 55566 [ame=http://www.amazon.com/Compu-Fire-Phase-Charging-System-55566/dp/B001J8M2LW/ref=sr_1_2?s=automotive&ie=UTF8&qid=1355072600&sr=1-2&keywords=Compu-Fire+40+Amp+3+Phase+Charging+System]Compu-Fire 3 Phase Charging System 55566 : Amazon.com : Automotive[/ame]
Also... which one is better... Compu Fire or Thunder Heart? ASM2005: Thunder Heart Quality Products
Thanks - Franco :cheers:
francoblay1
The Spaniard
What's the price on the ThunderHeart?
I would tend to lean towards it as the newer technology sounds like a plus.
Both at same price $300 in Amazon... TH about $10 more. [ame=http://www.amazon.com/Thunder-Heart-Performance-Three-Phase-Evolution-Style/dp/B000GVAVC0/ref=sr_1_19?s=automotive&ie=UTF8&qid=1355110223&sr=1-19&keywords=Thunder+Heart]Thunder Heart Performance Three-Phase Charging System for Evolution-Style Big Twin Motors : Amazon.com : Automotive[/ame]
UPDATE
It seems to me the TH is no longer available.... in some webpages it says it has been discontinued by the manufacturer.
Little-Boo
1. 55560 Compu-Fire 3 Phase Charging System 55560 : Amazon.com : Automotive
2. 55566 Compu-Fire 3 Phase Charging System 55566 : Amazon.com : Automotive
55570 is what I have on my 2006 Mastiff. I have the open primary. Look on the "How to Section" and look at Jake's install and replacement of the Stator. Call them, well from spain e-mail them and they will tell you which one you need. :2thumbs:
Carlos :whoop:
francoblay1
The Spaniard
Carlos, yes, I've seen Jake's How-To, I did contact him and he reckons hes is the 55560 but not 100% sure.
These are the differences I can see so far;
1. 55565 Product Dimensions: 14 x 12 x 10 inches ; 10 pounds [ame="http://www.amazon.com/Compu-Fire-Phase-Charging-System-55565/dp/B000WKBQHE/ref=sr_1_3?s=automotive&ie=UTF8&qid=1355115238&sr=1-3&keywords=Compu-Fire+3+Phase+Charging+System"]http://www.amazon.com/Compu-Fire-Phase-Charging-System-55565/dp/B000WKBQHE/ref=sr_1_3?s=automotive&ie=UTF8&qid=1355115238&sr=1-3&keywords=Compu-Fire+3+Phase+Charging+System[/ame]
2. 55560 Product Dimensions: 10.2 x 9.5 x 8.2 inches ; 7 pounds [ame="http://www.amazon.com/Compu-Fire-Phase-Charging-System-55560/dp/B000GV9USQ/ref=sr_1_fkmr1_2?s=automotive&ie=UTF8&qid=1355116055&sr=1-2-fkmr1&keywords=Compu-Fire+spacer"]http://www.amazon.com/Compu-Fire-Phase-Charging-System-55560/dp/B000GV9USQ/ref=sr_1_fkmr1_2?s=automotive&ie=UTF8&qid=1355116055&sr=1-2-fkmr1&keywords=Compu-Fire+spacer[/ame]
3. 55566 Product Dimensions: 10.8 x 9.5 x 7.8 inches ; 10.7 pounds [ame="http://www.amazon.com/Compu-Fire-Phase-Charging-System-55566/dp/B001J8M2LW/ref=sr_1_5?s=automotive&ie=UTF8&qid=1355116801&sr=1-5&keywords=Compu-Fire+3+phase"]http://www.amazon.com/Compu-Fire-Phase-Charging-System-55566/dp/B001J8M2LW/ref=sr_1_5?s=automotive&ie=UTF8&qid=1355116801&sr=1-5&keywords=Compu-Fire+3+phase[/ame]
4. 55575 Product Dimensions ? [ame="http://www.amazon.com/Compu-Fire-3-Phase-Charging-System-55575/dp/B000GVE8S8/ref=sr_1_14?s=automotive&ie=UTF8&qid=1355116801&sr=1-14&keywords=Compu-Fire+3+phase"]http://www.amazon.com/Compu-Fire-3-Phase-Charging-System-55575/dp/B000GVE8S8/ref=sr_1_14?s=automotive&ie=UTF8&qid=1355116801&sr=1-14&keywords=Compu-Fire+3+phase[/ame]
5. 55570 Product dimensions ? [ame=http://www.amazon.com/Compu-Fire-3-Phase-Charging-System-55570/dp/B000GVC92K]Compu-Fire 40A 3-Phase Charging System 55570 : Amazon.com : Automotive[/ame]
Either one will do. And since one is N/A, all you need is stator and rotor. What are the other wrapped parts, spacers/collars? You can buy a harley volt/reg or any aftermarket v/reg that pushes over 14v at idle and above.
All you care about is a wad of clay compressed onto the side of a wired prong. You now aim for X to Y:
X is the prong that faces the rotor magnets.
Y is the clay to dial in the middle of the magnets to the prong.
Z says the shims dial in that X to Y position for a more balanced wave form.
You think that is more for backing the rotor away from the case? I think you more want to shim that magnet over that prong in the middle for some reason?
Five Five
My Stator shorted out so I just went with the standard 32 amp Harley EVO setup. i checked the output on it and its putting out more than the BDM. 14.4 volts at the battery. If you search around you can find it for about $150.
