Yep. X2Stuff a rag between the chain and the clutch sprocket. Then apply steady pressure with a breaker bar.
Here ya go bud, works like a charm! Place this between the teeth on the engine sprocket and the chain and use an impact wrench to loosen the clutch hub nut. Like the others said, the nut loosens clockwise.Hi, I thought I would try and post this here. Does anyone know where I kind find a Clutch Locking tool. I need to remove the inner primary and can`t get the clutch assembly off. The nut is to tight for the impack driver to work. Let me know.
Thanks
