RRRUFF
If you are not getting a red led to light up on the Ig. module up when you hit the run button and you have power at the ig. module, I would start with the ig. module.Thanks for the reply!!
When I hit the run button, I have great power everywhere (where there should be atleast) However, The LED does not light up on the thunderheart.. So im guessing its my cam sensor.. Does anyone know where or what part # I should order?? I guess ill go ahead and replace it and start from there.
Or Ive done some research and seen Crane cams makes a nice kit Comes with Coil, Sensor and Wires? Is that easliy installable or not worth it?
