Dog wont fire
RRRUFF
Thanks for the reply!!
When I hit the run button, I have great power everywhere (where there should be atleast) However, The LED does not light up on the thunderheart.. So im guessing its my cam sensor.. Does anyone know where or what part # I should order?? I guess ill go ahead and replace it and start from there.
Or Ive done some research and seen Crane cams makes a nice kit Comes with Coil, Sensor and Wires? Is that easliy installable or not worth it?
If you are not getting a red led to light up on the Ig. module up when you hit the run button and you have power at the ig. module, I would start with the ig. module.
Re4peR26
I understand, However when I left the key on and unplugged the module then plugged it back in, The red LED did light up, Not for long.. However I Guess it could be bad... Where would I go about to get a replacement? or upgrade?
Ok, did a number of tests... I got power to everything I checked for an arc from coil got nothing, Got power to coil, Got power coming to and leaving the thunderheart so... Im going to have to say its the coil... On the cam sensor I took that all off cleaned it throughly, Looks like its in good working order, However i think I may have to replace that aswell.. Because sometimes my bike would die so that may have something to do with it.
Without a multi-meter how did you determine there was power to the coil or to the module?:confused:
I would hate to see you spend $400 for a simple ground issue or a $20 cam sensor.
At this point if you're not going to get a multimeter to check any deeper I would head to the Dyna website and pick out something appropriate.... :2thumbs:
Like this:
Dynatek Performance Electronics - Harley Davidson FI Controller
Dennis
Re4peR26
I used a multi meter, However the one I used did not have the RX1 on it to test the cam sensor. and like I said, When I hit run I have 12v everywhere, Just no light on Thunder heart and no spark from coil..
Re4peR26
I've used the multimeter.. However where in the world did you find a cam sensor for $20??? The ones ive priced were about 170 lol
Oscar Maldonado
Let me check my parts drawer at the house:lol::lol::lol:, I might have one laying around you can have. I'll post up tonight seeing I'm at work right now.
Deathstar88
my neutral light didnt work either.......it turned out that i had to replace the thunderheart control module.
Re4peR26
Yeah, Figured lol mine was working great one day then the next day nothing at all, Traced all wires including tach and still nothing.. and I have no LED so im guessing my module is just fried....Does anyone happen to have a replacement part # for cam sensor?
I Found one on fleabay for $20 from BigDogPartsKingPen, picked it up as a spare. Even has the BDM connect plug & play :up:
You can PM him on the forum if he doesn't have one up on Ebay I'm sure he's got a box full at his shop.
_______
There is one on fleabay now he wants $30 I'm not sure who the seller is. I would go to the ebay forum and contact BigDogParts
NEW GENUINE BDM CAM IGNITION SENSOR FOR BIG DOG MOTORCYCLES BDM170-00147 | eBay
Also if your looking for an ignition module here is an 04 for $80
http://www.ebay.com/itm/Thunder-Hea...Parts_Accessories&hash=item3f134bf174&vxp=mtr
New Cam Sensor + Igntion Module bout $100 :up:
Re4peR26
_______
Thunder Heart Ignition Module Big Dog Motorcycles | eBay
That Module, Will not work mine has 2 plug its 3 prong 4 prong, However I contacted big dog directly they offer new sensors for 140 plug and play style, Atleast I know I have some options.. I have a few more tests to run...
What I would really like to do it is just to simplify the bikes wiring.. Perhaps aftermaket ignition and wire plus would make this dog 98% reliable lol
Re4peR26
Here is a picture of my cam sensor, Does it look bad?
Also I was going to order one from big dog since its 34 dollars cheaper then harley but I want some longevity out of it lol My bike is an 04 with 7800 miles on it
stlmikie
I wish I had more money.
is that a bigass crack? Dude do yourself a favor get the censor and go riding! This is driving me nutz! You cannot tell by looking at it if it has failed. Unless it is just melted down. :cheers:
Re4peR26
lol, Yeah there is actually 3 cracks... Im going to order the sensor monday lol from what I see of the weather there aint too many nice days... Well I appreciate everyones knowledge and help greatly appreciated!
