Change your air cleaner and you'll like even more.....:2thumbs:JUST COMPLETED MY TOP END REPAIRS WITH NEW S&S VALVE ASSEMBLY AND INSTALLED THE 585 CAM . WENT FOR A ROUN D THE BLOCK TEST DRIVE AND I LIKEY \....:2thumbs::2thumbs::2thumbs:
:roll::roll::roll::roll:YEA EARL....ITS ON THE LIST TO DO WITH ABOUT TEN OTHER MODS...ONE PAYCHECK AT A TIME THOUGH..
Ok, you can't drop a line like that without elaborating! What do you like more about the 585? Lowend is better I assume...what else?:2thumbs:Last week I changed from 600 cams to 585 - very happy with it and prefer it over the 600.
The 600 kicks in at higher rpm's, so more upper end power. The 585 gives you more at mid range so most feel it's better all around. If you are only going to drag race, 600 would be better choice.Let me know if I am wrong but a properly setup 600 cam install will be great all around. Meaning if you had the heads built for the 600 it should perform.
BTW good for you Dogbone! I am wanting to get rid of my TP boxs as well.
NO QUESTION ABOUT IT!!! If you're going to do your heads, and match the headwork to the .600" cam, you'll be way ahead of the .585" cam in power and torque.Let me know if I am wrong but a properly setup 600 cam install will be great all around. Meaning if you had the heads built for the 600 it should perform.
