Ok, part of my wild weekend, I had to deal with oil puking down the side of my bike. I had to claen it off several times before I found where it was coming from. The oil is comimg out of the back side of my air cleaner.
This thread only talks about how to put a band-aid on it. I want to know why it's doing it in the first place.
I have the 03 chopper w/ the 107
I am useing Mobil 1 full synthetic for v-twins, with a KN-170c oil filter. I couldn't find any thing on the package that says what the microns are.
It was doing it worse at 70- 75mph. nothing below that, and not as bad running 75-85mph.
Why isn't it being sucked down the intake?
Does the banjo clamps have check valves in them, or is it the 117 and larger that has the check valves.
The plugs look ok, considering the air filter is totally soaked in oil.
My compression is good, and don't ask how many miles are on it, I have no idea.
I'm going to build an oil breather container, would it be better for it to be higher that the valve covers, or go ahead and mount it to the bottom of the bike?
