U
Underdog
Guest
K9's running on just the front cylinder with the engine cold. Please help.
Is it Fuel injected? If not it should not have any thermal shut offs.
First I would change the plug. Then swap the plug wires around to see if its the wire.
Then check wire connection on back of the coil.
Then current to the coil from the igntion
What V was suggesting is take the front spark plug wire off coil and plug then swap it with the rear. and while your at it check connections of the red, blue and yellow wires on the coil.Wires are stock, carbureted, and have been having battery/starting issues for the last month. I swapped the plugs, did nothing...
I can read. Thanks.What V was suggesting is take the front spark plug wire off coil and plug then swap it with the rear. and while your at it check connections of the red, blue and yellow wires on the coil.
Thanks. I'll look into that.Mine did that on the front cylinder at 1000 miles. I was about 4 miles from home and was able to get home on just one cylinder. Strokers Dallas tech replaced the ignition coil on warranty.
:flag::flag::flag:
From your reply sounded like all you did was change plugs.I can read. Thanks.
Earl I'd say we are done with this one.From your reply sounded like all you did was change plugs.
Excuse me....
Plus 1Earl I'd say we are done with this one.
