As a few have recommended, assemble the pack. Here are 2 things you want to look for without all the measuring, but to understand that wave washer.
1. Look at the fingers of that large wave washer, which is basically what it is. See the wear marks at the edge of the fingers? When you bolt that wave washer down at those tips, it is when you measure that flat part of getting the wave [hear me?], is getting the wave as flat as possible is the [watch this], is your eyes are the measuring tools.
a. Looking at the wave washer, the more wear of the plates, the more the wave relaxes back to how you see it in the static now = Less pressure ~ Slips and all that ~ Less wave tension = See that visual with the wave washer wear me back to memory?
b. Looking at it another way, you can put yourself in the cheap seats, say nothing to no one. What is the aim of the wave washer? To make it [flat is that gap]. So, will the wave know it is pushing on two steel plates? No. Will an extra steel plate flatten the wave for more tension so the used pack is being played out so in the cheap seats, you get to ride with more time playing out the parts? Yep. Add a steel to wave the plate back to flat.
c.Test for slip. If not slipping... Cha Ching!
2. Test for slipping> I'll say that the way to look at assembling the pack correctly is something called memory on the collapse.
a. Steel plates and frictions are stamped out of sheet metal? So there is a cut side and a smooth side. Feel the steel edges that may cut your fingers. Those face that wave washer. That is the stacking process to the clutch pack.
b. Same goes for the frictions. If you take your hands and push your fingers together, that is a flat meeting a flat steel on the collapse.
c. See the way memory fights that friction in between the steels? Now, turn one hand around and collapse your fingers over each other. See how they both are not fighting, but now clamping onto the friction [if the frictions are in the same direction] that is.
Universally, the pack is assembled this way for most bikes. The wave washer style is to make that wave as flat as possible = No tools needed, because there are so many parts that fit in the basket.
