hoat
OK the gear set is out of the bike and the case remains. Had that sucker ripped out in under 2 hours. I used a swing press in place of the actual press so I did not have to remove the case from the frame.
swing press
So what happened was the clutch nut came loose and the basket slammed repeatedly into the washer behind it and flattened that sucker out. metal shavings wore out the bearing and I am going to see if I need a new mainshaft. ordered the rebuild kit and primary kit from baker 280 for both.
washer
gearset
mainshaft
case in bike
swing press
washer
gearset
mainshaft
case in bike
