You have to read my stuff over and over. It is not confusing, it is condensed.
Ya wasnt hard to do! LOL
Should i switch plugs?
Do a compression test?
Wires?
Yes. Do not reread my penmenshithe guy's got it!
Please try explaining again...
WATT? You either do it or I'm going to start laughing with you.
Old dog i agree if the back is running leaner it would be brown as the front is running fat aka black! Ideas to correct?
Bad valve guide leak? Too much carbon?
1. Plug is wet = Oil fouled ~ Rings/guides.
2. Plug is dry, particles are black with soot = As dry to the touch, drawith it.
3. Plug is gas fouled like low compression = Wet, but better look quick. Does gas evaporate kind of fast?
This just touches what the plug is doing.
How do i match them up? Front could be stuttering due to overfueling? so go down on int jet?
Transition is both low and main jets sucking out fuel. You say you take off fine. How about just change plugs first. If that takes the stutter out, it says plug fouling:
A. Compression says: I'm going to have good compression, do not look here, I read book perfect as does the other cylinder matching compressions. If we are 10% off between percentages, I have a problem like one cylinder has kennel cough.
B. Valve Guide says: I am like a carb jet. Bet me I do not suck oil down the valve guide at every intake stroke, bet me. :roll: I may be adding to the fouling of said side.
C. The Squid's Golden Rule: Oh ufckQ! I'll never check compression first, I rather chase my tail than listen to you, you wit that attitude. :up: :lol:
