This check will eliminate your coil. If it checks good then you know it's not your coil so don't spend the money. One thing that comes to mind is you mentioned you replaced the plug wires. Are you sure you got the proper wires for your scoot? These things can be very fussy when it comes to plug wires also.
IGNITION COIL
• Electrically, rarely an issue. Typically, most electrical issues are due to poor
connections/crimps and broken wires. May crack at mount due to vibration on 2002
models. A reinforced coil cover will fix this problem.
• To diagnose, if by removing yellow wire and momentarily touching ground jumper to
negative post does not force a spark and all connections are known to be good, check primary and secondary resistance. If out of spec, replace coil. If in spec, check for bad plug wires and plugs.
Primary resistance: 3 ohms
Secondary resistance: 12,000 ohms
