Yep thats what I did. I ordered some new nylon washers also and replaced the old ones that did the trick. If that doesn't work or can't find the correct shim send me you addy and I will send you two nylon washers.Take it of the clevis were it rotates and there are little nylon washers..put another washer in basicly shim it...then tighten srew back up with some loctite blue.. that's what I would do...
Key not too tight! I stripped mine :bang:remove the screw holding the peg, clean the threads real good, apply some fresh blue loctite, and re-torque it until it is a little tighter and doesn't fall down. not too tight.
Yep exactly - add a nylon washer or two so you don't have to over torqueTake it of the clevis were it rotates and there are little nylon washers..put another washer in basicly shim it...then tighten srew back up with some loctite blue.. that's what I would do...
That's a good idea! No wonder you're KaptinAmerika!!A wave washer on one side of the peg works the best. No overtightening required. They can be a bit tricky to get in but once its done its done.
