Correct. I think it should have the caliper split line centered on the middle of the rotor width.Thanks, I took off the caliper and noticed that two pistons were extended about an 1/8 of an inch while the other side was fully retracted. Could it possibly be that only one side of the caliper is working? I put chalk on both sides of the rotor to see if that is the case. I will let you know what happens.
Bigdog Bro1, Are you talking about the spacers as the shims when putting the caliper on? If so, there are three and I put two on the bottom. I will check to see if it lines up.
