replace with utima - connections ?
hayseed
i am going to put an ultima motor in a mastiff (its rolling frame) and i am wondering how the electrical connections and oil lines will work/connect,,, will the old crank sensor from the original S&S be needed... how will the the tach get its readings ? also will the oil tank and lines connect in the same ? if anyone has done this i would appreciate some guidance
:bang:
MARV
Ultima uses a cam sensor. Basically same as a dynatek 2KI.
Tach wire comes from that.
Ultima used to have detailed instructions on their site
john sachs
:bang:
Oil lines will work the same.
No provision for a crank sensor. Nose cone ignition is usually supplied with their engines.
Tach wire off ign. system.
Electrical connections: Ultima igniton separate, easy to wire. All other connections SHOULD be easy to figure out. :eek:
John
