I recently had mine off to inspect the connection for corrosion while chasing my problem. Did you make sure the pin connector was on good when you put it all back together? It's a little difficult to get your fingers in there on the connector. I had to take a small screwdriver and gently push it sideways on the connector to get it on good.Kiwi, quick question. That Black Wire where/how does that disconnect?
Trying to take the board out in one piece. I installed some new grips and low and behold nothing works on the right side anymore :bang:
