I concur that WP should be offering better customer support.That may speak well of bdmridgeback, but not so of wire plus, who is the manufacturer.
Got power to the ignition module? If so, you need to check the power output of the module then check the wires from the module to the coil. Power to the coil comes from the ignition module and has nothing to do with the WP.I am not geting power to the coil and need help to resolve.
There ya go ... Thanks Dennis!Got power to the ignition module? If so, you need to check the power output of the module then check the wires from the module to the coil. Power to the coil comes from the ignition module and has nothing to do with the WP.
If there's no power to the ignition module you need to check the wiring between the module and pin 5 of the 6 pin connector of the WP.
Dennis
No sweat!There ya go ... Thanks Dennis!![]()
:up:When I had my Ridgeback, I fried the hand control module, I called WP and talked to a real person the first time I called, part was covered under warranty, sent the bad one to them and they sent me a new one. Great customer service from them.
both it looked like, nothing against women at aircraft factories alot of women are electricians building harnesesladies or lesbians?
I am not clear on your nomenclature. The service manual calls the coil the ignition module. I think you are referring to what the manual calls the EFI controller. I checked the circuit in pin 5 and see no issues. It shows 12v with key on. All the circuits are continuous to coil.Got power to the ignition module? If so, you need to check the power output of the module then check the wires from the module to the coil. Power to the coil comes from the ignition module and has nothing to do with the WP.
Dennis
Ah-h-h... I must have missed where you said your bike was fuel injected. I don't have the WP wiring for that. However, the coil is still the "ignition coil" and instead of an "ignition module" you have the "EFI controller", separate beasts.The service manual calls the coil the ignition module. I think you are referring to what the manual calls the EFI controller. I checked the circuit in pin 5 and see no issues. It shows 12v with key on. All the circuits are continuous to coil.
There were some special connections with the EFI module. Try doing a search there was an EFI WP install question like last week on here...I am not clear on your nomenclature. The service manual calls the coil the ignition module. I think you are referring to what the manual calls the EFI controller. I checked the circuit in pin 5 and see no issues. It shows 12v with key on. All the circuits are continuous to coil.
What I see occurring is the relay that powers the fuel pump, coil, injectors and o2 sensors dropping to 3v with key on. If I remove the relay and jumper across it the pump runs and I get 12v at coil.
The control side of the relay reads 12v with the relay removed and key on. With it installed, the control side and output side drop to 3 volts. (battery still at 12v).
I also swapped relays and nothing changed.
:bang:
