kmalysa
I pulled my clutch pack and inner primary to replace seals on inner primary. I DID NOT dissassemble the clutch pac itself.
Yet when I reinstalled and tried to adjust clutch push rod, I am getting no movement to engage or disingage( clutch lever just feels like I am streching the cable, hard to pull?).
In fact, to get a feel for how it works, I even removed the clutch rod completely, then took up the clutch cable slack, and the lever is hard to pull and I feel or see nothing moving????
Could the ball ram have been damaged? The only thing I did wrong on initail disassembly was forgot to remove slack in cable and clutch rod prior to removing throw out bearing.
Everything functioned fine before removing clutch pack and sprocket.
