Its recommended in the S&S engine manual. I think its due to stretching of the bolts but not sureIs it mandatory to replace engine case cylinder studs when jugs removed for headwork and honing?
The motor only has 3000 miles…117 cu in S&S.
Thanx again
Harley used to recommend changing the studs for the same reason. They also tell you not to retorque them after assembly is done for the same reason...I think its due to stretching of the bolts but not sure
