Just for an update if anyone was interested. I had a wire broken twice, no problem with the tender afterall. Sorry Don won't be buying one today,
The positive wire terminal lug was broken and I had repaired that first, but still no charging......
I took a known good battery and attached my tender with the clamp pigtail and it worked normally, so I knew the charger was ok.
I then took a meter to my pigtail on the bike checking continutiy of the the negative wire, checked fine, then the postitive wire from the connector to the fuse was good, fuse checked good, but there was no continuity from the fuse holder to the terminal lug. The wire was not only broken at the lug, which I had just fixed, but it was also broken from the fuse connector inside the plastic fuse housing.
The fix was I just removed the clamps from the second pigtail and terminated with ring lugs and installed that pigtail on my bike. Tender is doing it's thing again.
Was a little puzzling there for a day or so, you wouldn't think the same wire would be broken twice in just a 4" piece, but it was. :2thumbs:
